2013 Silverado 6.2L max tow Hitch class
Hey!
Im trying to figure out what class Hitch I would have on my 2013 Silverado 6.2L with the max trailer package. Would it be a class 4? Reason I'm asking is I'm looking for max tongue weight on the truck. I pull a three horse trailer fine but now I'm curious... haha
If factory, then class 3/4. Also look in owners manual in trailering section. Should also have a sticker on hitch with info (if it did not come off like my 15)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
