trans swap 4 speed to th400
Hello. I was wondering if its possible to swap my 1987 TH400 thats been recently rebuilt into a 1990 GMC 1500 4x4 with a 350 engine and a 4 speed manual. I dont care if the 4x4 works as i just need a work truck. Is it possible to just get rid of the transfer case? Also what will i need to get / modify to make this work? Thanks for the help guys!
