FS '81 C10
For sale, a 1981 Chevy C10 Std cab, short bed. The body is rough, and the interior is just as rough. but it does run exceptionally well and was a reliable daily driver for many years. It has a 267 small block V8 2bbl and a 4spd manual trans.
Here are some of the things I've put into the truck recently
-New ball joints, all four
-New A-arm bushings, all four
-New idler arm assy
-New front brakes with new rotors
-New brake system proportioning valve
-New4 core radiator
-Separate engine oil cooler
-New battery
-New dual exhaust system from the manifolds back, with new mufflers. Dual outlet to both sides.
-New cass/radio with 4 speakers (2-3.5"/ 2-6.5")
-New clutch
-New Eaton Posi unit
-New Richmond 3.73 gears
-New Differential bearings and seals
-New rear brakes with new hardware
-New brake drums
-New in bed tool box
-New column mounted tach
-15x10 chrome rims with 4 tires at about 60% tread (2-BFG Radial T/As, 2-winston KO tires)
Now here are some of the things that could need attention.
-No dash pad
-No carpet
-Bench seat is tore up and has a seat cover over it.
-Rear bumper bent at corner
-RF fender needs repalcing
-Some rust on the rocker panels and floor below the door.
All I'm asking is $850 OBO
E-mail me at: [email protected] with any questions or comments and I can send you some pics as well. Thanks.
    overspeed
    overspeed
  • Who's Online   3 Members, 0 Anonymous, 1,102 Guests (See full list)
