Limited Slip
Hey, does anybody know the difference between these RPO's... 2003
G80 (Axle Positraction Limited Slip)
G86 (Axle Limited Slip)
Thanks
The G80 is the Eaton Locker, if you want to know more go to Eaton.com they have everything you ever wanted to know.
I am embarassed to ask this question but what is the difference between a limited slip and something like a locker???
The eaton limited slip works with carbon fiber clutch packs and spring pressure for its operation. The new locker is completely different and actually locks the rear. As posted above, the Eaton.com web site is really good at explaining it all. The E-Locker is really cool because you can control when to lock the differential by a switch. :confused:
Hey Black02, where is this switch, if there is one?
Sorry if I was confusing on the E-locker. The only vehicle that comes factory with that is the H2. Other wise you would have to order it from Eaton and install it yourself.
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 357 Guests (See full list)
