2003 Tahoe 4wd Problems
hello guys,
im ALex from Germany...i drive a 2003 tahoe since 2012. The car has 150 kmiles on its back ...since a few days ive problems with the 4wd. When im drive on the german autobahn the auto4WD jumps in without touching the panel!
the problem accurs randomly...today i just drove on the highway...i had to stop at a cross road suddenly the 4-hi jumps in while im trying to turn right into the road...this also without touching the panel...i am bit confused..does anyone know what the problem can be? it would be very nice if someone can give a short note :) we aint have a gm dealer arround here
have a good one !
alex
It is all electronic. I own a Tahoe 4wd and an Avalanche 4wd.
Your front hubs I believe have sensors. When they get bad, it won't go into 4wd. It might be reverse ? Drops into 4wd ?
Or ? Your switch panel is lose and a bump activates the switch to drop it in 4Wd.
I'd think sensors myself being I just replaced mine on the Avalanche.
Sent from my iPhone
thanks for the info...tomorrow i will pull out the switch and check it...the sensors in the front hub are for the anti lock breaking system..i think...
but i will put an eye on that too....
Yeah, the sensors in the front are for anti lock brakes, but my bet would be those same sensors detect wheel spin for the auto-trac. Do you have it in 2wd or Auto 4wd
its in 2wd...but like i said suddenly it shifts into 4-hi.... i can manualy switch back to auto 4wd but to get back into 2wd i have to stop and go neutral.
yesterday it did it again on a short highway trip....but on my way back (same road) home it dont...
Sounds like a bad Transfer Case Switch to me. I would replace that first.
If you have access to someone with GM SPS I would also flash the TCCM Module with the updated Calibration. GM had issues with Trucks starting up in 4low and pushed out a TCCM programming update some time ago. I dont think this is related to your issue but good insurance if you have access to SPS.
hey thanks for writing back... the guy at the shop hookt his snap on scanner to it and noticed that 8 different errors saved to the unit... i dont know which particular but i will tell him your advice also! i would say the TCCM is shot... the proplem is we dont have a GM dealer out here who can flash a update to a new or used one... and i have to search for where i can get the software :(
If he has a pass thru device you can rent the a two day pass from ACDELCOTDS.com
Not sure how shipping would working with customs going to germany if not you could mail me a tccm and I can program it on the bench per your vin.
hey thanks for your help! i appreciate it very much :) i will tell the guy from my shop downtown this adress ...maybe he can figure it out...
if nothing works lets see whta the customs will have for sending the tccm to you :)
thanky you and have a good one !
alex
    CaptainDad
    CaptainDad
  • Who's Online   3 Members, 0 Anonymous, 588 Guests (See full list)
