Gibson exhaust STOCK #5656
What are your opinions on Gibson exhaust from cat back? Specifically model "5656" they sound pretty good on 5.3 v8 which I have but seems like a less popular brand.
Gibson is cheaper and sounds just as good but was wondering if any members have experience with them ??
I have the 5.3L with 8 speed (2016) and I recently put on the Gibson 315628 single side cat back system. Looks very smiler to the 5656.
I'm very pleased. Sounds great, even in V4 mode, and seems to have added some power and I think maybe 1 mpg.
The single swept side Gibson is decent. Definitely an upgrade from stock and won't drive you crazy with drone. Fairly quiet at low RPM but when you put your foot down it'll give a deep aggressive growl. Just keep in mind this is the most conservative sounding exhaust they make. If you want a loud agressive cackle, this isn't it. You will want lap band clamps sized to fit this exhaust as the U-bolt clamps that come with Gibson exhausts are complete junk. Some guys have had cold-start exhaust leaks with Gibson exhausts.
thanks so much for this write up. My brother is the one who recommended Gibson to me vs magnaflow/flow master since I was looking for a less expensive option so I could do the intake/exhaust together vs one at a time.
I will go over all that with him and see what he thinks. I do not need anything too loud and obnoxious but definitely don't want to deal with exhaust leaks or less that adequate quality of the components. I would just rather pay the extra 2-300 and get a magnaflow/flowmaster at that point if that is accurate.
thanks again!
Is it the most conservative sound compared to other brands as well?
I don't need anything obnoxious or too red neck. Just anything is better then my current prius sounding 5.3 LOL...
I am more worried about some reviews I saw online that said the fittings/clamps were not quality so there was leaks.breaks, etc. ...but then I read other reviews raving about them lol.
in your experience is it worth just paying for a flowmaster or magnaflow? I mean we are talking a couple hundred bucks and I plan on keeping truck awhile.
It's hard to say if it's the most conservative sounding of all brands, but it's definitely on the quieter side. It's your typical turbo muffler sound. The piping is fairly big so it's a really deep burble at warm idle.
I've debated swapping mine out for a 14" Magnaflow setup. I want something a bit more aggressive to match what I've done to the truckk so far.
you currently are running a Gibson exhaust from cat back?
Yep Gibson single swept side.
Basically what I was looking at. How is the v4 drone? And did you have any issues with the Gibson brackets/clamps?
I've got the Gibson Metal Mulisha cat back (single exit) on my 2015 Silverado and love the deep tone it produces, it's loud though so definitely not for everyone.
Couldn't tell you how bad the V4 drone is, I disabled V4 at 1500 miles on the odom. The U-bolt clamps are junk. I had one of them snap when I was installing it. The best option is to just weld it. Lap band clamps are the 2nd best option. The joint on the factory flex pipe has leaked for some guys. Most either sent it back or had a shop weld it.
3
I watched about seven videos of the mulisha exhaust on 5.3s tonight. For the price and tone I think immature pull the trigger and pair it with an Airaid or k&n intake with the extra cash I'm saving not going with flow ,aster or magnaflow or borla.
I would just weld it so I guess reviews about shitty clamps won't apply
Also the metal mulisha is def louder then the Gibson side swept stock #5656 ?
The only thing I would suggest is possibly getting an Range AFM disabler because the V4 drone is kinda annoying to me but I've talked to others that didn't mind it so much and we're able to deal with it . I haven't had any problems with my clamps that came with the system (knock on wood) but getting it welded is definitely the way go.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 440 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
