2016 Interior Lights and Footwell Mod
Hey guys, love this site! So much to do on my 2016 SLT 2500 4X4. First one is the footwell lights. Doing my site research I see the XK Glow white pods are as close to an exact match. However this was on a 2014.
Are the 2014 interior lights the same as the 2016? Mine are a very white LED.
Thanks!
Thanks!
Should be the same man. I had a 2015 Sierra and my 2016 is the same
GEN5DIY has some LED interior lighting solutions and know their stuff. They also have LED backup lights and several other goodies. I would check them out, great service when I had my Non SLT to SLT headlamp harness made (which GM said could not be done). It works like a charm.
    Policeoff01
    Policeoff01
  • Who's Online   4 Members, 1 Anonymous, 745 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
