Wheel Height
I am wondering what the height is on everyone's 2000 or later Yukon or Tahoe (XL or Burb, too) as measured from the ground through the center of the wheel to the top of the wheel well?
Could you post the front and back height of yours here? I only ask because I recently replaced my shocks with Bilsteins and the factory coils with bilstein coils and I want to see if the height is back to factory normal. I also am thinking about cranking the torsion bars in front and maybe some coil spring spacers in back to raise it up further. Right now, mine are:
Rear: approximately 36.75 inches
Front: 35.5 inches
I do have different wheels/tires with a resulting diameter that is 0.8" less than stock so add that to my measurements and you get:
Front 34.5"+0.8" =35.3"
Rear 36.25"+ 0.8"=37.05"
Looks like you are right in there.
<edit>I just noticed that yours is a 2WD. Mine is a 4x4 so this info may be useless :confused:
