Tonneau for 2011 Sierra on 2016 Silverado
When I got my 2016 Silverado, I was hoping to be able to use the tonneau cover from my 2011 Sierra on it. The tonneau cover is a GM tonneau cover (part 20962145). The problem is that the tonneau cover has alignment tabs that are supposed to go into the front stake holes but Chevy, in its infinite wisdom, decided to cover up the front stake holes.
I figure I have three options:
  1. Remove or cut the tabs on the cover so that it lays flat on the bed rails
  2. Cut the stake hole covers out
  3. Get a new tonneau cover
Option 3 is obviously a little pricey and I don't really want to cut out the stake holes. That leaves me with option 1.
I'm wondering if anyone else has run into this problem and what their solution was.
You are probably in a better position to answer your own question. Does it fit? I wouldnt hack up my truck or tonneau to make-do.
Better to sell it and offset the cost of a new one if it doesnt fit.
Well, I assumed that it would fit the new truck since both trucks were crew cabs but I did, as you suggest, put it on the new truck to make sure. It does fit, dimension-wise, it's just the tabs that are, or were, a problem. I decided to cut them out. I wanted to remove them intact but could see no easy way to do it so I just cut the tabs that held them in. It was soft rubber so it didn't require too much effort.
The cover fits just fine. I just have to spend a little more time aligning it than I had to before.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
