U Bolt Tightening
None of you...NONE...have posted the correct torque specs at all for the U bolts.
K2 1500 TRUCKS:
FIRST PASS: 59 FT.LBS.
SECOND PASS: LOOSEN 180 DEGREES.
THIRD PASS: 59 FT.LBS.
FINAL PASS: 120-140 DEGREES.
The bulletin says to TORQUE TO FACTORY SPECS. Not some random number that folks think is right based on the interwebs.
  • Replies 31
Yes, I tightened them on my 2017 CCSB sierra. Got rid of the clunking that was exaggerated by the clunky 8 speed when it was new. 5k miles and its smooth, except for the shakes at 70+, i paid extra for those.
