June GM Incentives
Firetiger(MN)
They're not up yet on the corporate site, but I believe you can still take delivery now (6/2/03) and get rebates that were up during May. Am I mistaken in this, cause I read it directly from the GM.com site.
Also, how long will the 0% APR financing be around?
Today was the last day (well right now AK, HI still have a chance) extra $500 on Tahoe/Suburbans. I thought I it was on everything though. It was also given to those that opted for 0 for 60. Memorial Day Cash.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 1 Anonymous, 620 Guests (See full list)
