2015 1500 5.3 true straight pipes?
TheLPGuy
I have a 2015 Silverado 1500 5.3. I currently have muffler and resonator delete single exit. All my past cars were performance cars true straight pipes. No cats no mufflers but it was tuned for no cel or any codes. That being said I have not been able to find a video or anyone doing this on their 14/15 Silverado 1500. Lots of people label their videos as straight pipe but then they just have a muffler and resonator delete. Does anyone have a sound clip of true straight pipe? I want to decide within the next couple months if I was to do straight pipes and then tune the truck.
    Fishboat
    Fishboat
  • Who's Online   6 Members, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
