04 Silverado 5.3 exhaust upgrade
Looking to switch from my Magnaflow dual exhaust cat back system to a possibly a Corsa or flow master series muffler. My goal is to convert it to a single side exhaust. But I'm not sure on what size inlet and outlet muffler I need. I plan on just cutting the old muffler out and welding the new muffler. Any help would be great!
It really depends on the size of the exhaust pipe on the outlet side of the cats. Sounds like you just need a two in/one out muffler. I would probably go with a 3" outlet on the muffler if you are concerned with flow. And I would probably guess that the pipe size is 2.5" on the outlet side of the cats.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
