Running board question
Mr_454ss
Negatory even the link you posted states:
Chevy Silverado/GMC Sierra 1500 2014-2016 photo_btn.jpg 76400-01A Plug-n-Play Conversion Kit only
Chevy Silverado/GMC Sierra 2500/3500 2015-2016 photo_btn.jpg 76400-01A Plug-n-Play Conversion Kit only
Same part number: 76400-01A
Only cab size matters.
That part number is only the P-n-P conversion kit (just harnesses meant to be used if you already have the "old style" Amp boards installed). The new kits that include the boards and all the P-n-P stuff are different for the 1500 vs. 2500 (the brackets and some hardware are different).
The only kit that is different is the one for diesels due to the DEF tank.
76154-01A plug n play kit is for 1500/2500/3500 double cab/crew cab gas trucks trucks
75154-01A is "old style" kit for 1500/2500/3500 double cab/crew cab gas trucks
76147-01A is plug n play kit for 2500/3500 double cab/crew cab trucks with diesel and running board requires modification to fit.
Above info is directly from AMP Research.
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 665 Guests (See full list)
