Dash light going out?
My PNRD12 light will go dim after driving a little bit or it will sometimes not even come on, yet sometimes it is bright as it should be, what is causing this? c32a5c0cee104d679e53b4d17a0e65bc.jpg078bdaa3d3e7eec9538865ee3cfe5dcd.jpg
Common issue for those clusters back then. You need a rebuild done. While having the rebuild done (don't try to do it yourself) have them convert all the lighting in there (back lighting for the cluster) to LED, you'll be happy you did. Do a web search, or you can e-mail a trusted friend of mine from another forum to talk about your cluster and get all your questions answered. Just tell him GoBlowSnow from SBF sent ya. He does this stuff quite often on the side and also fixes FOB issues for the keys. Good man.
[email protected]
Cheers
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,137 Guests (See full list)
