Spindle lift - help
Paulb909
I have a 2016 2wd Silverado with a 2" level kit,
Been recently thinking about going 5-7" range
SoCal super trucks quoted me $2500 out the door for a 5.5" spindle lift
They claim the truck will feel like stock and that I don't need to change any other suspension components ?
Is this to good to be true ?
The only negative I heard from them was that I have to get new wheels.
They said he factory 20" wheels would not work with the lift
