94 chevy k1500 upgrade to 2500 leafs.
so considering upgrading my trucks rear leafs to 2500 suspension. guy before me put 4:10's front and rear with eaton lockers so the only thing keeping her from hauling heavy stuff is the 4 flimsy 1500 leafs. i just recently hauled an 1,800 lbs trailer with 3,600 lbs of scrap on it and it sat her down a bit. so my question is will the 3/4 ton leafs fit on my frame? already checked the reese hitch specs it will haul the weight. someone told me the shackle mounts will need to be moved (i know the shackles will have to be upgraded as well). my other option was to add a leaf, but not to sure about that. thanks
it sure can be done..
but other things will be stressing.
I have even ripped a cross sill off the ears.
one half is still flexing, the other was being a brick.
I have calmed down since the early 90s of hacking the wimpy half tons..
Hellwigs helper under the u-bolt has been great. I limit my own truck by enforcing bumper, welding the area in front of it to lock out any thought of a receiver.
good factory half should gain 100 over the bumper specs anyway. (500 tongue - 5000 tow)
a lot of weird things can happen bricking the back.
I just got a high performance tranny mount installed recently for example..
check my build thread out, it is a classic overload case, and full recovery.
if to go full swap springs, my own 2 cents..
there is a 2000 pound setup from suburbans. that will bump up the half ton limit, and respect the rest of the half ton, staying about 500# under 3/4 ton.
..and seriously, get rid of those U-bolts.. do not reuse the wimpy u-bolts on the rear springs.
A tip when it is done.. go over articulating terrain, the rear springs should be active as the front.. don't let it brick.
I would look into adding SuperSprings. People there are very helpful. I added them to my 2500HD to increase the payload from 2800 to 4000 lbs and they work perfectly. No change in the ride with no load and with a load the shocks work much better as the springs are carrying the weight and the shocks only have to provide dampening.
Be aware that the truck frame is another limitation. Lots of pictures of trucks with broken frames on the internet. I had a front leaf shackle break free completely on a truck without any extra stress, only too thin a frame section. Newer trucks have fully boxed frames for good reason.
  • 3 weeks later...
The springs keep you level but the bearings carry the load. Plus your tires will need to be upgraded. You'd need to move up to a load range "E" if you want to carry a heavier load. Wheels also have a specific load range rating.
If you just want extra height, no problem.
To actually safely carry the load I'd swap the entire axle to get the benefit of beefier bearings. And consider boxing your frame for additional strength. And don't forget that heavier loads need bigger brakes.
Do you have the 14 bold SF axle? If so then you are good to upgrade to the 3/4 ton carrying spec with just springs and tires. That 14 bolt SF axle had a 4800 lb weight rating when on the 3/4 ton trucks.
    ballencd
    ballencd
  • Who's Online   4 Members, 1 Anonymous, 595 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
