Brush Guard?
I have a 2014 Silverado. Does anyone know of a brush guard or front bumper that has a hitch mount. I have looked every where and cannot find one for a 2014. There has to be one out there.
Thanks,
I've looked as well and can't find one either. Was thinking of welding one on to a brush guard.
I don't like how low a front hitch goes. I'm not lifted and the one I saw come in under the front plastic.
Interested to see any useful replies to this. Counting mine as not of much use :)
