06 Silverado Backup Camera
Looking to install an aftermarket backup camera. What recommendations can you give me?
I put a Boyo VTL425 on my '08. It mounts above the license plate, but it does need a separate screen (my stereo head unit has video). It has made it through several years of harsh summers and winters, still functions great.
