Regear and tune
chrislcrews
Ah, I did not realize they were so different, thanks for the info as I was contemplating doing this in the future. I have read a few other threads and just want to make sure I understand but basically what I have gathered from it is that it is just a clearance issue with the stock housing, is that correct? I can't believe GM wouldn't have tried to standardize the housing so that all factory options would work.
Just going by the info provided by AAM on their website, they list the same carrier for both 9.5" and 9.76". Only way I would know to fit a larger diameter ring gear into a housing and keep production costs down would be to shorten pinion length and machine housing accordingly or produce center section of the housing from a completely different casting. However they are doing it, pinion gear needs to move .130" away from axle centerline.
When you did the gear swap, what did you do for a carrier? Did you do the Yukon setup using the earlier 9.5" gear set with the adapter yoke,etc or did you get a stock GM carrier and use the AAM gears? I believe you also had to replace the complete front 8.25" assembly?
[i used the AAM gears with the stock carrier. I am from MD so I took it to east coast gear supply and it was done in less than a day. Give them a call they know everything. I drove 6+ hours to have them do the work and would do it again in a heart beat.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 423 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
