New from Maryland by way of Georgia
Bubbasplorch
I wish it was under better circumstances, but..
I have a 2009 SiIverado. I was pulling out a gas station and I had to get into it a little too hard (traffic is bad on this particular road) and I basically had it an inch from the floor board, yes I know this is bad. When I finally backed off I realized that the "service four wheel drive" icon was on. I first thought, ok its scheduled maintenance that is build in. Then when I slowed down to drop someone off I noticed it was driving like it was in 4-wheel drive. I thought, that is weird. My selector knob was in auto so I turned knob to 2-wheel. The light did not move, it stayed on auto. I let it coast for about 15 feet and it seemed like it was it 2 wheel. I drove back home and as I was pulling into the neighborhood it felt like it was in four-wheel high, so i drove about 20 mph to my spot. I pulled up and started backing in my truck dropped down to 4-wheel low, all while the selector switch was still in auto. I turned the truck off in neutral and cranked it back up and went from auto to 4-wheel low thinking it might help, the selector light stayed on auto even though the selector knob was on 4wheel low. I finally turned it off and took a deep breath (after a flurry of choice words).
I have finally narrowed it down to a few things after doing some research on the google. I would like some opinions on it, but I believe it is one of three things: 1) the fuse is blown - gonna check tomorrow after I have time to process my baby is sick. 2) It is something electrical, which if that is the case I'm screwed. 3) the transfer case is messed up.
Thank you for the help in advance.
  • 3 weeks later...
So an update. I let it set for a little while, and I went back out and it finally went into 2 wheel with the knob adjuster, I drove it around the cul de sac and it seemed like it is driving well, but I am not going to do anything with it until I can get the money to get it to the shop. Kind of puzzling.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,299 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
