ROUGH COUNTRY CUBES WITH RIGID MNT
wildwilly1
  • Replies 38
Sent from my SAMSUNG-SM-G925A using Tapatalk
Low beam first pic low beam with cubes 2nd pic
So you ended up not using the brackets at all? Did you have to remove bumper?
And did they plug right into fog lights wiring or did you have to wire them to the battery?
No did not use the bracket at,all . And i cut and wired them in to foglight wiring
This is a pic of the top of the housing
looks good. any close up photo's ?? is the 2014 , the same as 2015 housing ????
dont know about housing being the same sorry
your lamps, are they both spot ,food ?? why not put one set /w switch with fog lite lens ???
pretty easy just a lot of bolts 11 ,15mm on each side
Do you think there's anyway to get the brackets to work or there's no way? I really don't wanna bolt into my housing unless I just have to.
I couldnt figure a way
Nor could anyone else i had look at it
is the problem getting the lights attached to the bracket?
