WEBPHOTOS?
RyanbabZ71
How come all my albums i had on webphotos is gone?
I go and i am logged in and it shows no albums
WTF
Wonder if someone hacked in and deleted them all?
Im trying to log in but it tells me they are going through server maintenance.
Same here, I'm hoping my albums are still there and didn't get wiped out.
I will have to check that later cause that would suck if the pics are gone.  But now that I think about it, my sig pic is linked from over there, so I guess it is still there?  Hmm... ???
