97 C1500 "Service Engine Soon"
My 97 C1500 with the 5.7L vortek just started acting up. It began last week when I first started it in the morning, ran rough for several seconds and check engine light came on. Then ran smooth and was fine all week. I cleared the check engine light by disconnecting the battery. Saturday I started it, ran rough briefly then cleared up. Check engine light didn't come on. Yesterday, went out to do a few errands and ran fine when I went to the store. When I came out 20 minutes later and started the truck, it began to rough again. Check engine light comes on. Now the truck is running rough and won't clear up. Check engine light starts flashing, then stays steady for a bit, then flashes again. This pattern goes on and on. Engine feels like it running on 6 cylinders. :thumbs:
I checked all my plug connections and all seems fine. I did replace plugs, wires, cap, & rotor, and fuel filter a couple months ago. All OEM parts. :thumbs: The truck has over 80,500 miles on it. Had the intake gasket replaced about 3K miles ago. Before I go to the dealer (have an extended warranty that's good for another year), any suggestion as to possible problem would be appreciated. :thumbs:
Sounds like a bad oxygen sensor to me. The symptoms you are describing describe that exactly. My girlfriend's dad's expedition started doing the same thing last week...his is a 2000 with 60 thousand miles on it. He hasn't gotten it checked out yet, but we think it is the o2 sensor. Good luck!
Exactly where is the EGR valve located? I have looked for mine, but not very hard.
Scott
On 1996 - 1999 5.0L & 5.7L Vortek engines it is a black cylinder with an electrical connector on top, on the front of the intake manifold. Very easy to spot. Kind of expensive too, Wells EGR1067 - $119.99 or Wells EGR 1043 - $159.99 at Autozone. I don't know the difference between the 2, that's what shows up on their site.
As for other years, not sure where it's located. Hope this helps. :chevy:
Check engine light starts flashing, then stays steady for a bit, then flashes again. This pattern goes on and on. Engine feels like it running on 6 cylinders. :chevy:
I'm not sure if this is correct or not but, I was told that if the light flashes there is something major wrong. If the light comes on and everything seems ok, it is probably just an intermittent problem and it will correct itself after a set number of key cycles. (basically no worries) If the light comes on and flashes and there is a noticeable problem you should not run the engine.
Like I said, I'm not sure if that info is correct. It came from a GM Tech. though.
Autozone will scan for free, if you have one near by.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
