Leather tearing?
lee16silverado
Hello AllTerrainX,
Congratulations on your recent GMC purchase! However, I’m sorry to hear about this front passenger seat concern. We would be happy to reach out to your dealer on your behalf. In order to do so, please send us private message with your VIN, current mileage, full contact details and dealership at your earliest convenience.
Best,
Anthony J.
GM Customer Care
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
