duramax fifth wheel
My boss and friend is buying a new fift wheel trailer. He is looking at a model with three slide outs and one with four. They are over 13,000 lbs.
He owns a 2002 2500HD CC with the Duramax / Ally.
Is that to heavy ? it looks like the truck is rated to tow a fifth wheel not to exceed 15,200 lbs but will he be sorry he is lugging that much weight when he hits the mountain passes? He towed the work trailer with a Scat Trak Mini Excavator on it a while back and was pretty proud of himself. That wasn't up hills and when I told him that the Mini Excavator only weighs 11,500 he began having second thoughts about the big trailer.
What do you trailer towing guys think?
I believe your on the right track. He would be much better off with a Dually 3500 at that weight. There's lots of trailers less than 13K :D
I think it will pull it OK. The biggest problem I can see is that he would probably want a dually instead of the single rear wheel.
The dually would be much more stable when towing a long and tall load like the 5'er you describe.
If he is towing just occaisionally the 2500HD should be able to do the job.
I wouldn't think that 13K would be to much for that truck. But if he's like 90% of the people who think they tow a lot and want their truck to handle and accelerate the same then no he needs a T-200 Kenworth. My only concern would be cross winds and not the weight on the axle itself but on a rather narrow tire. four tires offer a lot more static friction than just two. Plus a 3500 has more springs and is heavier..
This is off of gm's duramax page. The 2500HD CC 8' has higher limits than the
3500HD CC 8'. So towing would not be a problem, however I would assume that the 3500 would give you far better stability under adverse conditions with a heavy load.
SILVERADO/SIERRA 2500HD AND 3500 FIFTH-WHEEL TRAILERING
ENGINE: DURAMAX DIESEL 6600 V8
TRANSMISSION: AUTOMATIC AND MANUAL
2500HD 2WD/4X4
MODEL BOX LENGTH (FT.) MAX. TRAILER WEIGHT(1) (LBS.)
Regular Cab 8 16,800/15,700 3.73
Extended Cab 6.5 15,800/15,500 3.73
8 15,700/15,500 3.73
Crew Cab 6.5 15,600/15,300 3.73
8 15,400/15,100 3.73
3500 2WD/4X4
Regular Cab 8 15,600/15,400 3.73
Extended Cab 8 15,300/15,000 3.73
Crew Cab 8 15,100/14,800 3.73
thanks for the info guys I have discussed it with my friend and now its his turn to decide what to do.
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
