Trans shifting hard
Hi, my 07 silverado 1500 With the 4l60E shifts hard after being run for a few minutes. I shut it down to get gas or to just let it sit. It will shift fine for another few minutes. It's throwing code p0700 and p2763. Not sure where to start. Thanks
measure the resistance of tcc pwm valve.if it is below 15 ohms replacing torque converter clutch pulse width modulation valve may fix your problem!
Clutch packs are gone. The electronics are trying to compensate for the worn clutches but can only do so much, you are on borrowed time. Order a new transmission or have this one rebuilt by a reputable shop.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,002 Guests (See full list)
