Color shifting headlights
RJP44
Anyone have color shifting headlights? Ive seen a few of them around but not many on 2014- 2015 silverados. I was kinda curious as to how they are done like that, is it an entire light you purchase, with additional wiring, using a remote? Or is it something where you must take apart the factory light and add internal color shifting LEDS? A quick check online and it seems Im finding more kits that i must take apart the headlights rather than buying a whole new one already built in.
If anyone has a link to new headlights with the LEDs already built in, please feel free to share. Post pics as well if you have them
I have the anzo u bar headlamps/chrome housing with led switchbacks installed. If interested, im about ready to part ways with them.
