I have a 2003, 1500 Silverado with battery and instrument cluster problems. I checked my VIN and my truck is not covered in the instrument cluster recall.
Issues with both seem to be all over the internet, but I wanted some more insight before throwing parts at it.
1. In cold weather the battery will drain to almost completely dead in 3 days and in the summer it start after 5 days of no use, but no longer.
2. Once the battery is dead, connecting the charger or jumper cables will cause the truck to go into panic mode and the horn will sound the panic beeps until hitting the key fob to turn it off.
3. I had a gauge stepper motor problem a few years ago and the stepper motors were all replaced by GMGaugeGuy.com. (the battery drain may have started around this time, but I don't remember which happened first) My instrument cluster has a tach, Speedo, fuel, battery, oil press, and coolant temp gauge.
4. Yesterday when I started the truck all of the gauges stayed off and the LED display portion of the cluster was lit, but wasn't displaying information. (the bottom half of the LED display had all fields lit and the top portion was off)
I disconnected the battery ground for about 30 minutes, reconnected and had the same dead cluster. I then followed one of the youtube guides that showed how many people found loose resistors.
I disassembled the cluster and was getting ready to test for loose parts. When I connected the cluster harness (ignition key off) The stepper motors powered and moved the gauges to the "zero" position. When I turned the key to "on" the gauges and LED worked normal without me doing the eraser press test on any of the parts. I poked around at the connections and everything stayed powered up. I then re-assembled the cluster and drove the truck to work today with no issues.
I'm tired of kicking this problem down the road and don't mind to replace the cluster but am not sure if it's truly a cluster issue or a power to the cluster issue.
I attempted to use my DVM to test for current draw but it seems like whatever is causing the issue powers down when I disconnect the negative battery cable to put the meter in line.
Does anyone have any troubleshooting suggestions?
Sometimes the processors in this style cluster just fail and cluster replacement would be necessary.
The other more common issue should have been addressed by the re-builder. Granted the issue may not have been present at the time. So without inspecting the cluster its really hard to point the finger at one of the two problems.
I repair these every day, 03-04 have this problem of cold solder ( made in Mexico ), the cluster failing to fire up is usually the 3 24Ω resistors clustered together to the right of the right speedometer background bulb.
three%2024%20ohm%20resistors_zps9ubxq0vw
Do not use an iron hotter than 750°F or you'll pull the copper foil off the board. Sometimes with the 03 the 2 bigger glass diodes above the speedometer motor will also get a cold solder.
If the PRND321 display is on but not the odometer then it's the lone resistor 1200Ω to the left of the voltage multiplier coil at the left of the tach motor
As far as your other problem, your cluster is suppose to shut down after 20 seconds, there's an electronic timer between the speedo motor and the 4 gauges to the right. This one is a bit more complicated to repair and will often necessitate the cluster board to overnight in the freezer to pin point. Did 2 yesterday that wouldn't fire up, they haven't called back to complain. Do not attempt any of these repairs if you are not familiar with a fine point low temperature soldering.
Edited by Coby7
Just finished a repair on a manual Silverado cluster, notice no PRND321 display.. This one was dead to the world when I got it. It had corrosion on the back side of the board, cleaned it and covered the spot with cutex.
Edited by Coby7
Just finished 2 more 2003 clusters for son and dad, both were dead. They're back alive, Both fully refurbished and LEDed in cool white.
Edited by Coby7
Here is a video of the timer shutting down after 20 seconds. This is a test I perform on all repairs to make sure the timer works. You'll see my hand reach behind to shut the ACC power in the beginning.
  • 4 months later...
Hey Coby7,
I'm in Cape Breton and I have an 06 Sierra 2500HD 6.0l. It seems that the IPC is the cause of the battery drain. Before I pull the fuse, the IPC is drawing around 250mA and once the fuse is pulled it drops to 15mA shortly after. There is a little delay before the current drops off to 15mA. Would you mind elaborating on what needs to be repaired? My trade is electrical. I could send it to you for an overhaul but I'm would like to repair the drain myself, if possible.
Deon
That problem can sometimes be hard to find, especially if it's intermittent. I sometimes have to use a heat gun and overnight it in the freezer to find the exact location of the problem. The delay shut-down circuit is on the right hand side of the speedometer stepper motor. This problem would be very hard for me to explain in words. The last one I did with this problem was for a guy in Halifax and it took me 3 days on and off to find the problem then I spent one day testing my solution to make sure it would shut down every time. That one ended up having a small metal whisker found under microscope between 2 pins on that big integrated circuit to the left of the oil pressure stepper motor .
Feel free to PM me for more info or questions!!!
Edited by Coby7
Oops I posted my email by mistake......
Edited by Coby7
  • 4 weeks later...
Great posts! and thanks! Have you ever had to replace the timer? Mine does Not go off, and will sometimes make a fast clicking sound as iff to turn on a stepper ( all are replaced and made sure no cold joints) My cluster is draining my battery I have found. I removed the cluster and the world is good , but cant stay like that .. Thoughts?Thanks, Bruce
Never had the timer circuit go bad, it's always filings,cold solder or copper oxide bridging.
  • 4 months later...
Hi Coby7
As with the other posts, My battery drains as well over time, But my instrument cluster powers up.
2003 s10 loaded options. After 10-15 seconds of turning off the truck the instrument cluster powers up and will run down the battery. inserting the key, opening the door or pulling the key out will stop it. For the 10-15 seconds and then it powers up again.
Tried body control module, no help and visually inspected cluster connector and back board for corrosion, cold solder joints, none found.
you mention the 20 second power down. could that chip be causing my issues?
Thanks, Zlrig
Sounds like your having RAP relay issues. RAP stands for Retained Accessory Power and this is sent to Instrument panel, radio power, window and sunroof so you can play with these after you have turned off the key. To me it sounds like this relay is stuck ''ON'' . Check the RAP relay on the BCM . Contacts may have welded themselves together. If your cluster is ''ON'' with no key check if windows will go up or down....
Edited by Coby7
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,236 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
