under hood tool box
1chevelle
Under the hood there is a place for a second battery. Does anyone make a box that will fit this battery tray? It would be handy to carry straps and tools in a secure box under the hood. I am thinking a battery sized box that opens from the top and installs using the factory battery clamps.
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 562 Guests (See full list)
