Yukon Denali 07 Fuel pressure
Hello ,
recently purchased used Denali 07 , and i love it ! , noticed the mileage was horrible even for a a Denali though , i started checking things and found the pressure on the fuel rail test point on idle is 95 PSI , engine off and pump on is only 50 , i was wondering if anyone has the specs for the engine running fuel pressure , if it is high what could be causing it? as far as i gathered from searching there is no fuel pressure regulator on my fuel system to check , can a bad pump module cause high pressure ?
Thanks for taking the time to give your input .
So the idle (engine running) should be 50? Any control module is there or only pump assembly? Which pump would you recommend as i saw some branded pumps that claim improved design?
if anyone can confirm the fuel pump is the cause of high pressure please do so i live outside the US and shipping would cost a small fortune want to make sure this is the problem thx
Pressure should be about 50 PSI, 95 is too high. Do yourself a favor and make DAMN sure you get a Delco replacement. If you buy one of the auto part store specials you will be paying shipping more than once in the near future.
