My 2014 Z71 / McGaughys / Fuel progress thread
  • Replies 30
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,121 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
