Oil dipstick tube replacement
Greetings all,
Today, I was starting the process of replacing my head gasket on my 2.5. The flange that connects the oil dipstick tube to the exhaust manifold was rusted to the bolt and, despite copious amounts of PB Blaster, the flange managed to move with the bolt, ripping it off. I've tried searching for a replacement tube, but I can't find any for this truck. However, I've found tubes for Camaros and Corvettes of the same time period. Are the tubes interchangeable from this era, or do I need to look harder for a tube?
