Sagging front end
What can I do raise the front end of my truck? It's 2001 GMC extended cab Z71. The front end seems alot lower than every other Z71 I've seen around. I'd like to make it level without having to lift the rear end to do so.
Under the cab at the frame rails you will see where the front torsion bars attach to the crossmember. There is one bolt on each side of the truck that hangs straight down. Turn each side in 3-4 turns and see how she is sitting.
This will raise the front end, at the expense of a stiffer ride, and possibly taking the front alignment out of spec.
BUT MAKE SURE YOU DO IT WITH THE FRONT END OFF OF THE GROUND.!!!! Not good if you don't....
Do a search for Ford Keys.... I added these to my truck and I wouldn't have it any other way (except for a full lift :D ). I had mine installed by a mechanic with a lift and it took him about 20 minutes. The truck is level now and you wouldn't believe in the amount of compliments and questions on what I did to level the truck. We lifted it about 2" to level.
Which direction do I turn the torsion bars? Clockwise or counter-clockwise?
What are "Ford Keys" and where do you buy them?
Correct me if I'm wrong but counter-clockwise is the way to turn them.
If you get a stiffer ride after turning them could you install some longer shocks and smooth the ride back out?
If you had waranty do you think you could get the GM dealer to align the truck under waranty?
Turn the bolts so that you would be screwing them in...
Ford keys have a different profile on them than do the GM Keys that are currently in your truck. When you tighten the bolts for the torsion bars you are making them ride on a different part of the lobe of the key. The Ford keys have a higher lift on the lobe, therefore you can increase the amount of lift on the front end.
Do a search for Ford keys, hill leveling kit (repackaged Ford keys), torsion bars. Volumes have been written on this site on this issue.
Tightening the bolts to raise the torsion bars is MUCH easier with the front of the truck off of the ground.
Don't forget to have your front end aligned now. Other wise you'll wear out the front tires!
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
