14 Silverado Back Seat Locked Up
I have a 14 Silverado Crew and the back seats have always just pushed up and pushed down easily. Now somehow the rear right side single folding seat is stuck in an upwards position and I cannot pull it down. It also seems as if the back is looser than the other side. Am I missing something? I don't see anywhere to release this...
Hello tgill,
I’m sorry to hear that you’re experiencing this concern with your Silverado’s seat. Have you addressed this with your dealer? If not, we would be happy to schedule an appointment on your behalf. If interested, please send us a private message!
Regards,
Anthony
GM Customer Care
Interesting as I have the exact same issue. Sometimes it works, sometimes it doesn't. and it does feel like the back of the seat is loose! Let me know what you find out if you take it in!
  • 1 year later...
Hey, I'm having the same problem with my 2015 Silverado 2500.  Rear right seat will go up but not back down.  How do I fix it.  I called the shop and will have them look at it but I'm looking for an easy fix.
Never had this issue on my 2016, I always lift mine up when I get groceries and pull it back down when I take them out.  No resistance, it just works. Good luck
    DaleB
    DaleB
  • Who's Online   4 Members, 1 Anonymous, 1,298 Guests (See full list)
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
