'99 Silverado 6.0 issue
I have a mid-year '99 Silverado 2500 with the 6.0l. Mostly it runs very well. Minor issue is a hard start (extended crank time) after driving for a while. I can start cold and it will start quick and easy. Drive it for any length of time. If it sits for less than a few hours (run in store, etc) then it takes a long crank time before it starts. When it finally does it seems like it just barely wants to start and I have to give it a little throttle for it to really run right. After that it is fine. It also has a heavy fuel smell after that. I'm wondering if a pressure regulator is going or something else? No codes.
