Removing silver plastic trim around air vents
27 minutes ago, STRMTRPR said:
if you're asking about the driver's side vent trim.. remove fuse panel door, pop vent/trim panel straight out, if you want to remove the piece with the headlight buttons it is held with pressure clips to the vent/trim panel
Yep, exactly.......so I can pop off JUST the silver trim part, leaving all the interior "guts" as-is?
Correct. Drove mine like this for a month lol looked horrible but it was worth it [emoji23]
So, whoever has added vinyl to their plastic trim pieces, any suggestions/hints as to how to make good, wrinkle-free corners?
I used heat, and had to experiment around to try and figure out when to use heat, where to use it, etc.
If I used too much, the vinyl would get flimsy and wrinkle.
If it was too cold, I couldn't "work it" enough to work out the wrinkles.
Any and all suggestions are welcomed!
