Anyone have the zone 1.5" body lift installed on their truck?
maxum3300
Does anyone on here have the zone 1.5" body lift installed on their truck? I'm curious if the gaps are visible to the point where the performance accessories gap guards are needed or if the factory skirts are enough to cover the gap. I have a severe rubbing issue after having my rough country lift and 35" tires installed. I think the shop that did my lift may have installed the wrong lift. I specifically asked for the 7.5" lift as I had been reassured by others as well as rough country that this lift would clear the 35s. Unfortunately I am away on business but when I get home I'm going to call rough country and ask them is there anyway I can tell what lift I have installed? I would assume the 7.5" lift would have a 7.5" strut spacer but when I eyeball it it looks more like 6 inches. I could trim it but don't know what's involved and how much metal is behind the plastic wheel well trim. Problem is the shop that did the install is 200 miles away so taking it back to them isn't all that easy. Of course if I call and ask what they installed they're just gonna tell me it's a 7.5" kit. I need to confirm this with RC before I accuse them of anything. Problem is next week I absolutely have to have my truck so I need to have this rubbing issue resolved immediately.
Measure your fender height to see your lift height before you call. That would be unfortunate if you were given the wrong kit, but it's a very strong possibility that either a) rough country said the kit will fit 35s but neglected to mention it will require trimming or b) whatever your using for wheels whether stock or aftermarket have the wrong offset to what was tested to "fit" by rough country
The only spot you will see a gap is between the bed and the frame right above the wheel. The gap doesnt look bad to me but thats me. No other spot will you be able to see that it has a body lift. I have the factory sierra wheel liners and they do not cover the gap. The gap you see is about an inch between the frame and the bed.
I have the zone 1.5 body lift and the 2.5" level kit. Like mentioned the only place there is a gap is behind the rear wheels under the bed. Its not even noticeable.
  • 5 months later...
zmnypit, do you happen to know what your fender measurements are with the 2.5 level + 1.5 body lift with your 33s? Thanks!
Body lifts don't affect suspension at all correct? Been looking to add this to my Fox 2.0s.
Anyone have a picture of the gap for reference?
Thats correct. Just lifts the body off the frame. Only gap is under the bed behind the rear tires but its not noticeable.
To the poster above, its 41.5" to the bottom of the fender.
    ar0517
    ar0517
  • Who's Online   2 Members, 0 Anonymous, 755 Guests (See full list)
