will 305/55/r20s fit?
31 minutes ago, Sakison said:
You answered a lot of questions for me.  That is the same set up and tire I am looking at.  I ordered a moto fab 2" spacer that goes under the strut though.
If you have stamped steel control arms, you will rub with a 305 and factory wheels.  I ran that setup, it rubbed on the sway bar and upper control arm quite a bit.
  • 1 month later...
4 hours ago, VANSICKLERM said:
I have a 2012 Gmc sierra denali on 2.5 in level/lift and want to keep stock rims. Would 305/55 fit on mine with no rub?? Want something wider
you're in the wrong forum, this one is for 2014-2018 trucks
  • 4 months later...
Jason so what if I went with the 2.25" FRONT LEVELING KIT W/ CONTROL ARMS - GM 1500 TRUCK by ReadyLIFT on my 2017 could I fit the 305's with no rub?  Will I need the spacers?
On 2/16/2017 at 12:02 AM, Justin Bowden said:
Update, I got the 305/55r20s installed today along with my 2.25 inch procomp level. On stock 20 inch slt wheels, no rub even at full lock, No spacers needed.
Did you have to replace the upper control arms? I thinking of the same tire on my truck but with the 2.25" ReadyLIFT kit with upper control arms.
With factory wheels?  You will probably still rub on the sway bar with factory wheels at full lock.  It won't be terrible though, I lived with it on my truck.  I was able to reduce the rubbing a little by running a small 1/4" spacer on the front wheels.
Yup the factory 20's. So getting the spacers will help then. So I'm curious how Justin who started this thread how he got his on with no rub as he states with no spacers?
I'm really not sure how he's getting away with zero rubbing.  Like I mentioned, my 305s with a leveling kit rubbed alot on the control arms and sway bar.
I'm actually very surprised those tires fit. It's usually the width that gets you and rubs on the UCA and sway bar. Not a lot of room in the rear of the front wheel well. I'm looking at 275/60/20 which maintains stock width, but increases diameter to 33". Not convinced they will fit. Looking at 20" aftermkt rims in +10 to  +18 offset , to push the tire out just a hair. I have no problem using zip ties or modding the felt liner. It's the lower rear of the front wheel well that has the black plastic trim piece on it that I keep looking at.
I did the Bilstein 6112's up front on 3rd setting. I have a little more room than stock, but have turned my steering wheel all the way on both sides and there's very little wiggle room on those damn square wheel wells.
  • 10 months later...
I'm sure you probably already got this figured out since this thread is like 9 months old, but figured I'd add my experience.
I'm running 33x12.50r20 w/ the same stock wheels as you. It rubbed pretty bad on the UCA so I added 1.75" bora wheels spacers. It now rubs the fender liner slightly at full lock, but nothing crazy. No more rub on the UCA though.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,222 Guests (See full list)
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
