SAE Terminal Conversion
This weekend I'm planning to convert the battery terminal ends to the standard SAE posts. I'm using an optima 34/78 battery (part number 8004-003). I've always had issues with the GM style connectors loosing. My question is when I replace the battery cable is there any fusible links that need to be installed on a new battery cable from the battery to the junction box?
Dont replace the cables, no need to. Change the ends. Dont like the replacement ends? Use plasti-dip in Black or Red.
I was looking at it earlier and it didn't look like there was enough wire to play with to switch it over to the post terminal connectors. I think I'll just get some copper lock washers to put between the terminal and the connectors.
Good idea, and youll need longer screws, which is a chance to get that tiny hex head screw POS outta there!!
Guys who put in big stereos usually have a stud in the battery
