Finally got pics of Bumper Replacement
Here are the pics of the Ranch Hand style bumper replacement I got from fellow GMTC member, brodee. This is on a stock 2wd truck, and the bumper was painted to match brodee's Pewter metallic truck. I kinda like the color combo on the Indigo Blue truck...now all I need is a lift and some new tires to get it looking like i want. What do y'all think? :sigh:
http://www.imagestation.com/picture/sraid6...cf/fbd50843.jpg
Wowsers! I don't know what Brodee drives, but I bet it's some kind of locomotive! That thing looks STOUT!
Just a personal opinion: I think that the mesh stuff (between the two uprights) "competes" with the diamond plate a bit much. For me, there's a little too much going on with the mesh. I'd be inclined to remove it.
Other than that, once you get some lift and tires on that truck, I'd be scared to death to see you coming in my rearview mirror!
Enjoy!
-Kirk
There are pics of brodee's truck on this thread:
Bumper Replacement
I do find that more cars tend to move out of the way when I'm coming through (might just be my imagination though) :sigh:
The thing probably weighs about 300 lbs. and dropped my front end a little more than it already was.
It looks good on there, better than it did on my truck! I can attest to how heavy it is, or at least my foot can :sigh:
That is one BAD @SS, GET THE H*LL OUTTA MY WAY, SOB! :flag:
I'll bet the ricers cringe when they see you coming up behing them with a full head of steam! That thing is stout! :sigh:
Is that a custom built Ranchand look alike or an older ranchand? The punch plate don't look right and receiver should be in the pipe and the bottom should also have punch plate.. The only reason I asked because I've had my ranchand front, rear and headache rack stripped so I can add some stuff before re powder coating them and they look different.. Maybe different on the HD..
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
