Muffler Swap
Matt9285
If you click on the link you provided there are options where you can choose what diameter piping you want for inlet/outlet. There is a 3" in 3" out option.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
