TPMS/low pressure alert
So I noticed my truck felt a little spongy/drift yesterday and sure enough my left front is showing 27psi per the tpms and the other 3 at 35psi. But this did not set off the low tire pressure alert on my DIC or dash. Could it be a faulty sensor even though it's broadcasting the correct psi? Any time I've aired down for the beach I get a tire pressure alert as soon as one tire gets below 28psi.
I am sure you already know this, but it could be a bad battery/one going dead in the sensor. maybe have the dealer reset them.
I'll be going to the dealer tomorrow to have a screw plugged or patched that I found. I was going to mention it to them, was just curious of the various reasons/causes it wouldn't trip the alarm. But the sensor must be working because it's sending the proper psi to the DIC (double checked all of them with a pressure gauge).
The window is suppose to be 7 PSI from the sticker on the door. If the RCDLR hasn't been tampered with you should have had an alarm if your PSI is 35 on the sticker.
Sticker is 32. 7 psi seems like a pretty high tolerance but that would explain it.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
