Bed Lighting in tie down holes
Static
Anybody know of any LED light systems I can install in the Tie Down holes that have the oval plugs in them? There are 9 of these, 3 on the front and 3 on each side of the bed. I would like to install the lighting either in all 9 or at least the 6 on each side. I dont really like the under rail lights as they dont seem to put on enough light. It may be all for not as cant seem to finding anything of the like.
This is the area I am talking about.
bull-ring-chevy-bullet-is-angled-for-bes
Yeah but there is only two of those holes as opposed to 9 of the others
Yes, I know. But I would assume you could do what he did in that thread to all those other tie down points. It's the same thing pretty much...
Those are LED lights that are made for a 3/4 hole which just happens to be the size of that hole. I don't know of any that are made for a oval hole. If I did I would have them already. I could probably mount those in that rubber plug but that's not the clean seamless look I want.
These are the only oval ones I have seen. Not sure the sizing of the plugs off the top of my head though. These are 3" by 1.625"
http://www.rigidindustries.com/led-lighting?f[0]=field_product_family%3a11
    thefultonhow
    thefultonhow
  • Who's Online   6 Members, 0 Anonymous, 682 Guests (See full list)
