DRL 4157 or 4114 bulb?
I have an 05 1500. You see many Chevy/GMC trucks in this generation with burnt out DRL's. What's the best bulb to use so that they won't burn out? I see conflicting info on whether to use the 4114 or 4157 bulb. Thanks.
4114. GM had a bulletin calling for the 4114 as it was a 14 volt bulb that could handle the higher output of the GM charging systems which typically run between 13-15 volts.
Funny you should mention that; I, too, noticed the many burned out lights. So back 2005, when I bought a new Suburban, I bought two new bulbs for when the inevitable would happen. Twelve years later, those two new bulbs are still in the glove box. I guess not all bulbs are created equal.
Well I went to replace the bulbs and can't seem to get the original bulbs out. Is there some truck to pull them out of the connector? The connectors are mighty burnt and charred looking.
Yep on the LED replacement. Look on Amazon for the replacements. Just need to orientate the bulb correctly for polarity.
bbwb
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 399 Guests (See full list)
