2016 2500 HD trans doesn't shift up when towing
On 5/28/2019 at 9:59 PM, Jak860 said:
I know this is an old thread but I just experienced the same problem as the original post. I have a 2105 Silverado 2500HD 6.0, 6 speed automatic, 36000 miles.  I was towing my loaded toy hauler that weighs in at roughly 10,000lbs. While climbing a long grade in manual 5th in tow haul mode the truck eventually slowed to under 40 mph in 3rd gear then shifted automatically into 2nd at 4200 rpm. Once the grade started to taper off I backed off on the throttle and expected an upshift into 3rd but it never came. Instead it stayed in 2nd even on the level with my foot completely off the gas. The only way I could get it to upshift is to move the selector up into neutral while coasting and then put it into drive range. It would then go into a higher gear. Several times when I tried to place it back into manual 5th it would drop all the way back into 2nd with high rpms. Then after driving awhile longer in drive range all went back to normal until it had to drop back into second while climbing a grade. It did this several times over 300 miles. I used to build and repair transmissions years ago. It acts like a stuck governor valve did way back when. I'm a little concerned about taking it to my local dealer as they don't seem to have the expertise or even the concern to a problem that is out of the ordinary. I have canvassed the web but haven't seen anything that may address my symptoms.
My truck did the same thing and still does to a degree.  For what it's worth my 09 2500HD which for all intents was the identical truck did the same thing.  It's not just your truck nor is it abnormal... it's likely all of them.
GM's tuning sucks for one... they can't figure out the most basic things like a working shift strategy.   So what did I do with my 17?  Custom tuning helped a bit but not a hell of a lot... it still will do the hang shift and just sit there revving with no load for no reason at all.  Gears actually helped with it a lot... and I sort of counter the downshifting myself.  With the 4.56's now I will downshift the truck to a sweet spot like around 3200 to 3500 ( fourth gear) at the base of the hill loaded and it holds it just fine.   The odd thing is when I do that and then click up a gear at the top it actually upshifts and drops the rpm.  If I let the truck do it's thing whether in tow haul or normal mode it does that rpm hang in a low gear it no longer needs to be in for what seems eternity before upshifting.  I haven't found a tune work around for that.. and the way these E78 ecm's are I don't expect to either.
I know it's not right but considering I have experienced the exact same thing with more than one I don't think I will fix it without a better rewrite on the software.
  • Replies 31
Thanks for the reply. At least I won't start chasing ghosts. I have 4.11 gears and live at 3000-7000 feet. I will be doing a supercharger as soon as I can drum up the extra cash. Hopefully it will keep me from having to drop down to a gear that screams.
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
    • Very often the part number on the trim part is just for the vendor order/assembly plant and will not show up in the parts system.  They won't make a bunch of extra parts that were not ordered. Keep in mind, lots of these parts were made to be "just in time" parts meaning they were dedicated to a vehicles ordered and sequenced for assembly.       Also, trim parts will often say, paint to match.
