Hard clutch pedal wont go down
Hey guys, so i am having problems with my Slave or Master cylinder. I have no clue why its doing this but with the slave cylinder not installed into the bell housing or attached to the clutch fork my pedal is rock solid. I took the master cylinder and slave cylinder apart, cleaned then, and even went the extra mile and blew compressed air from both sides of the line to get any debris out of the line, i than bled the system and my pedal goes to the floor the first couple of times then all of a sudden wont go anymore. When this first happened i assumed it was due to a bad clutch but again i took the slave cylinder off and tried without it installed and it still does this. Not sure as to why but it is pretty frustrating. I hope someone can chime in and help me out, i have checked the obvious (air in system ect)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
