Lift blocks? 4 vs 5"
Any cons on running a 5" block over the 4" that came in my skyjacker kit?
I like my truck to look a little raked and to me it looks like my front end is higher than my back end now.
the taller the block the greater chance for axle wrap if you tow, also it would be better if the blocks were tapered
That's somewhat of my fear. I pull a 22" ski boat a lot during the summer. Once a year we go past the 3 miles to the local dock and hit broken bow or lake Travis both are a few hours each direction.
I'm worried if I get the soft ride leafs they will be to soft to pull with though. 4" leafs and a 1 inch block would do the same thing without that huge block underneath.
get airbags or deavers
I have the 4 inch rear block as part of my BDS lift. A few months ago I contacted the shop that installed the lift to inquire about installing a larger block - I was told to avoid going any bigger than the 4 inch block due to potential axle wrap. I found the response a little strange considering the fact that the BDS 6 inch lift uses a 5 inch block. Incidentally, I also found it confusing that a 6 inch lift uses a rear block that is only 1 inch higher than the 4 inch block used on the 4 inch lift. At any rate, I've temporarily tabled the idea, but the two other options I considered were: (a) add a leaf; or, (b) airbags.
That's what I saw to and said well... if it's in their kit why the hell not. I could get the 4" springs and add a 1" block but I'd rather spend 50 bucks over 425.
I'm also considering a 1.25 body lift just for a little more height but I'm not 100% sure on it yet. It barely fits in my parking garage at work now. I think another 1.25" I'll be smacking my roof antenna for sure.
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 511 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
