Centerline Stingray III
Hey i was thinking about putting these on my green 03 z71 tahoe and was wondering if anyone had any pics of them on any vehicle. I saw somewhere that some guy had just put them on his yukon but i cant find the site... What is your opinion of these wheels??
What size tire would you run with these?? I'm not planning on dropping it or anything.
here is a link to the wheel http://www.centerlinewheels.com/wheels_det..._id=14&sw_id=76
Thanks in advance for any input
I looked at these wheels, but then I saw the Centerline Stingray wheel. I like that one better. Little more pricey than the Stingray III, though.
If I were you, I'd run 20 x 8 wheels, with 265/50/20 tires. That would be a good size that would fill the wheel-well, but would look good without lowering your rig.
my $.02
Lazerguns,
I just put a set on a new Sierra SLT ExtCab 4x4 Quadrasteer in Pewter. The set I chose were 17 X 8 Polished mounted with Bridgestone Dueler Revo's in 265/70/17.
They are about an 1.5" taller than the 265/75/16's and the 8" wheel sticks out about 1" more than stock. They do a good job of filling up the wheel wells.
IMO they look great; classy, understatedand and not quite as flashy as the Stingrays or any chrome wheel. The size you chose should be based on use. Low profile 20's just don't work well off-road.
Cool Wheels has them in polished for $185 each.
I will try to get some pictures over the weekend.
Greg
I'd love to see those pictures too laser.... I've been looking for some new rims and these are nice. I think I would stay with the stock 16" rims as I will do some off-roading, now All I have to do is find out if they will stand up to the punishing of OFF ROADING??
Thanks.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
