2015 Silverado Left Instrument Panel Fuse Block: Fuse sizes ?
I'm trying to do the thing where the fuse in position 10 gets moved to position 11 in order to put the dashboard accessory power outlets on Retained Accessory Power instead of battery-direct.
But I am having trouble relating the diagram in 10-48 of the owner's manual to what I see on the fuse block. .... My guess is an issue with my limited spatial relations ability plus the manual not telling the orientation of the block.
The positions on the block are not labeled, but each fuse has it's value printed on it - so I figure if I can find a diagram of that block showing each fuse's value, I will be able to relate it to what I see on the block and 10-48 of the manual.
I moved the fuse over so the power outlet. When you take off the fuse panel door, it was very explicit. Just match up the picture with the actual fuse panel you shouldn't have any issue.
Sent from my SAMSUNG-SM-N920A using Tapatalk
The one that says "50" on it?
If so, that would be in position #10.... but there does not seem to be an empty position #11 to move it to.
Or is the thing that says "50" on it not a fuse, but rather some sort of cover with fuse(s) underneath it?
This may sound like I'm being dense... but I don't want to go prying around in there and maybe short something out before I know the whole story.
10 and 11 are within the same slot for that 50 amp fuse. Once you remove it you will see there are 3 slots. The way this one is pictured I have moved it so the power outlets under the dash only have RAP. The factory position would be in line with the bottom edge of the two 15amp fuses flanking it.
Got it!...
Moved it up one, leaving a blade exposed below the 50 instead of above and now I have RAP on the dash sources.
Thanks !
